M Mark E30 New Member Aug 31, 2009 #1 Has anyone a 1uzfe without a gearbox on it? Basically after the distance in mm between the mounting face for the gearbox (on the 1uz engine) and the flywheel end of the crankshaft. Hopefully this isn't too vague Many thanks Mark Oxford, UK
autronic Member Aug 31, 2009 #2 If I have measured correctly it is 4 mm, measured this when I started to mess around with a custom flywheel.
L lexplay New Member Aug 31, 2009 #4 ha ha i was double checking it before i pressed quik reply so didnt see your post autronic. i measured it at 5mm and so did ed.
M Mark E30 New Member Aug 31, 2009 #5 Cheers guys to clarify, the end of the crankshaft is 4-5mm proud of the mating face? Thanks for your replies
