Today I had need to purchase 4 high tensile (greade 8.8) 10mm x 125mm bolts together with nuts.
They were to mount the steering box to the chassis of my vehicle.
The correct size is 10mm and the torque reading is 85-94nm.
Cost of the bolts and nuts was a little short of $110.00.
The nuts stripped at 55nm which meant I was a long way short of what I needed plus well out of pocket.
I took the bolts back (together with my Torque Wrench, so they could see the setting) and their literature gave the bolts a yield figure of 45nm. HMMM what to do?
I then found I could buy cap head bolts of a simillar size but grade 12.5 (I think) that had a yield figure of 78nm. Much closer.
The trick bit was the cap head bolts with nuts and 8 new washers cost a total of $35.00.
I like cap heads bolts for their look plus to have greater capacity at 1/3 the price is stunning.
Next time you order some bolts check out the price of cap heads over conventional.
Sure you need to use an Allen wrench to hold one end but the saving makes it look worthwhile.
