rivmasta
Hey all,
The oil pressure weve been seeing is 50psi at idle cold, 25psi warm. Under revs this increases to 50. I figured this is ok, other 1UZ's ive seen are the same.
Yesterday though I ran the oil breather lines out ofthe rocker covers to an oil catch can and under revs its now pushing 90psi! Im figuring this is way to high and Im risking blowing seals out.
Needless to say Im going to put a bigger breather on the oil catch can. Anyway, would I be correct in assuming that the PCV valve is in the rocker cover breather on no 1 bank?
