Correct Drive belt for 90 Celsior
Japanese_Mouse
Hi all
Just finished replacing my water pump.
And I bought a new Drive belt (fan belt), I recieved a Dayco 6PK2250 and it was challenging to fit.
The belt I took off was a 6PK2275 (a bit longer?).
Did I recieve the correct belt for a 1990 Celsior? (Hydrualic fan)
Would the belt be the same as a 1990 Lexus LS400 which has a Mechanical driiven fan?
Thanks
Car goes good, just have to source some new Sumitumo Leads. Lex where are you?
The belt is the same regardless of version of 1UZ.
Being an inch shorter it will be tight to start with but with a bit of wear it will be OK.
