Clint_LJ78
Good day everyone, I recently purchased a 1991 Toyota Land Cruiser LJ78. The previous owner had a 1UZ engine installed about 12 years ago. The engine is running fantastic but the cooling system is starting to show signs of wear. The previous owner installed a second, smaller radiator as well to help keep the engine cool during long trips.
The original radiator is still installed with an electric fan. I replaced the thermostat the other day and noticed a lot of rust particles in the water. I can only assume that this is from the radiator and that I will need to consider to replace it urgently. I am planning to rip the old primary radiator and fan out to replace it with a new radiator and fan setup. I suspect the secondary radiator may still be good enough to just clean properly and put back in again.
I would appreciate it if anyone could assist me with a diagram or suggestions on how to go about replacing the cooling system. The engine is still completely standard and no modifications has been made. Thanks in advance guys! Cheers!!
