Ok so I have a QM hydraulic release bearing and basically want to convert it to a standard clutch fork with slave cylinder etc. Any ideas which push system works well with the R154? I realise there will be some custom work, just looking for a starting point.
Look its not a debate, the unit has the recommended distance from the bearing face to the fingers, and twice in a year I have had to remove shims to increase clearance.
So if we can go back on topic about a fork and slave option that would be great.
I was thinking about converting my vehicle to a QM hydraulic throwout bearing until I read the below comment from the web page above.
I would have liked to install the QM throwout bearing, but to do this adjustment it is a major job as my motor and gearbox has to be removed from the car to work on the gearbox and clutch.
MAINTENANCE:
1. Check your working clearance and adjust as necessary. As the clutch wears, you will have to decrease the amount of
shims as the spring fingers come up.
I am running the dellows bell and R154, this has a fork and slave set up and seems to work fine. I have posted pictures in the drivetrain section many moons ago, you will have to plough through to find it or I could email you pictures if you are interested.
