Hi Guys
I am new to this forum and from South Africa. Wow what a lot of interesting info to be found on this site.
I have done various after-market EFI ECU installations on vicious engines installed in Toyota Hilux 4x4 trucks. I am now for the first time getting in a Truck in with a IUZ conversion running on a Microtech ECU. The existing installation is picking up errors with the CAM sensors so we are going to change the setup completely to make it more simplistic with the minimum connections possible. This vehicle is a dedicated off-road toy and the owner takes it to remote areas where the "bush mechanic's” skills are very limited, so I want to get the setup as easy to work on as possible.
My favourite aftermarket ECU is a locally manufactured one called Dicktator (www.dicktator.co.za)
I am going to install a Dicktator ECU on this truck (the Microtech will be removed)
The crank pickup will be replaced with a 36-1 wheel. The Dicktator-V8 box will be connected to the OE Toyota crank sensor via its own dedicated screened wired running straight from the ECU. As a matter of fact I am rewiring the complete engine loom as the existing one is already badly cut and hacked when the Microtech was installed.
I believe it is easier, neater and more reliable to start a new loom from scratch rather than cutting and joining many wires with colour changes in a single circuit etc.
The ignition circuit will also be changed from its current form, i.e. we will use the 4 channel ignition output signals from the Dicktator ECU to run a wasted spark setup, getting rid of the existing twin distributor setup all together.
I have seen on this forum where someone else (motoriderbc)used 2 MSD coils from a Ford (http://www.lextreme.com/forums/showthread.php?t=5326&page=14&p=94528) in his setup. I like this idea a lot except I can find any place locally to make me the Custom HT leads he used.
The other option would be to use a CoP setup. This is where my question comes in. What coils can I use that will be a perfect fit to the plug space in the head of the 1UZ that will seal the hole properly watertight. There are local performance shops that can get me any model of MSD or Accel coil I want but they do not keep sample stock so I can’t go and find the correct model. I hope someone here has done such a setup before and can maybe provide me with a model of coil and perhaps some pics of the installation.
Thanks
Thanks
