Do you guys think its more effecient using mechanical fan then hydraulic fan? I think this conversion would be pretty easy just to change the hydraulic pump to fan bracket. It would be interesting to know the effeciency and longivity of the conversion. What do you guys think?
Additional pages that might help with deleting the hydraulic fan and converting to an electric one:
Main article here: How to Convert a Lexus LS400 Hydraulic Fan to an Electric Fan - Lexus-Toyota UZFE V8 Performance Engine Forum
How to convert hydraulic clutch fan with electric fans.
Lowboy NZ - That is what I thought a peice of cake.... Well check this... First off you need to remove the radiator and fan assembly, hose lines etc..., no biggie, then you need to remove the serp belt and all that plastic crap around the engine bay...Way over kill on the plastic stuff by...
www.lextreme.com
Clean Hydro Fan & AC Delete
Just finished this up today so thought I'd share. Cut the original idler pulley bracket off the hydro fan pump and welded on a small piece for support. Used a 61.5" belt and it fit perfect.
www.lextreme.com
Hydraulic Fan pump removal
Hi, I've just bought a 1UZ engine(rear sump) for a project, The engine has the Hydraulic fan pump ,with a high pressure line and large bolt holding it on, i would like to remove the complete unit, coz i want to run Electric Fans, and ideas on the best way to remove it? Thanks
www.lextreme.com
hydraulic fan pump removal, possibilities
so im wondering if its possible to just remove the hydraulic fan pump from the front of the motor alltogether. im not running power steering or ac so im thinking i can just run a belt from the crank to the tensioner to the alt. im concerned with the bolts that would be missing tho cause i...
www.lextreme.com
Hydraulic Fan
Hey can anyone of you guys tell me the best way to bypass or disable the hydraulic fan oil driven pump? Loop and bridge the in and out lines to the hydraulic pump or disable and plug? I have my car apart now and trying to figure out what to do with this pump. If looped does the fan oil still...
www.lextreme.com
Hydraulic FAN
We use the original Hydraulic fan for cooling water radiator. The trouble is - It works constantly, all the time when the engine is running. Is someone having documentation for this? Or What make the fan works all the time? Where we can control the operating method? Please...
www.lextreme.com
