Converting from hydro to water pump.
white_raven
So I start to pull my hydro system off, and I was able to figure out that the bolt holding the pulley on is reversed. But now I cant get the pulley off at all. It's totally stuck on, and I can't reach the bolts behind it to pull it off. Any help would be appreciated! Thanks!
The pullys are on a taper so often require a puller. If you are not going to reuse it cut it off or grind a bit more clearance so you can get a socket in.
Oh awesome thanks alot! I Do have a puller so I'll work on getting it off this way first then if that doesn't work I'll just cut it! Thanks again!
