Badmanners
Hey guys,
I just purchased a 92 ls400 that was sitting for quite a while. Maybe a year and a half. I am going through the whole car and catching up on delinquent maintenance. I recently replaced the fuel filter and cleaned the MAS. After I put everything back together and started it up I took it on a short drive and noticed that is was struggling at Idle when I stopped, Cut out as I accelerated. When I got the car back to the garage I cut it off and cut it back on and got a CEL. when I counted the code off the flashing CEL I got code 31. I assumed I had not plugged in the MAS correctly or did not clean correctly and re did those steps. I’m still having the same issue even after I reset the system.
other Known issues are that the dash lights flicker and temp gauge reads normal then pugs to max and then normal, and the Odometer and speedometer do not work. I am hoping these issues are related to the pulling on the wire harness in the back left of the trunk hinge.
but I can’t figure out why is was running fine and now can’t idle to save its life. Any suggestions would be much appreciated. Thank you for your time.
mph and yes I confirmed the fuel is pointing in the correct direction.
thanks again.
thanks again.
