Code 19 for TRAC
Aphox
G'day,
Traction control was playing up with the TRC light lit up in tacho. Appears to be not working, or only working extremely randomly.
Everything else throws no codes, this throws a 19.
19 - TRAC motor ON and OFF operation is higher than a predetermined number of times (accumulator pressure leakage)
That's great to know... i've looked around and cant seem to find how to rectify the problem? A vacuum leak on the trac module or.. i don't know...
Trac problem
I have the same problem. If the pressure is leaking from the traction control, then it is a brake line leakage, which more than likely is the line between the traction control pump and accumulator. It's located under the brake fluid reservoir, above the driver's fender well, and in front of the driver's side valve cover. I've also heard a couple say that they found a leak behind the fender well on the passenger side, by the strut.
I fixed the leakage, but the mechanic let all of the pressure stored in the accumulator out, and now I have the leak fixed, but no traction control.
Hope it helps diagnose.
