1992/SC400
I have a problem. I changed my sparkplugs yesterday and the wires were old and a few broke so I bought new ones along with distributor caps and rotors. When I was removing the drivers side distributor I dropped one of the small rubber pieces down into the timing cover. At the time I figured that it didn’t matter because it was small, rubber, and would probably settle somewhere. After I got it pieced back together it started fine but the check engine light came on and showed a code 13 and you can tell that there is a small miss at idle and also when you are driving. I don’t know what to do so your help would be great. I’m hoping that rubber piece would not throw out the timing but don’t know. I don’t even know how to check the timing one these cars or if the rubber piece has anything to do with it so any help would be very appreciated.
