I have a 1994 LS 400 with 203,000 miles on it. I have only purchased it recently and it's been great. Since purchase the radio works sometimes and then just turns off, no power. I checked the wiring around the radio and did not find anything loose, cut, or weird. I thought it was the radio so I put in an aftermarket radio using a plug and did not cut anything. That radio had the same issue. I'd be riding down the road and it would start turning off and on again. I finally bypassed the "switch on" wire and made it hot all the time. Radio works fine now.
That was a few months ago. Now the climate control center will just turn off for no reason. When it does I have no lights at all on the climate control. It obviously turns off the ac/heat when this happens. I looked at the wiring and see nothing obvious wrong. I did notice when it first started if I turned my parking lights on the unit would come on, strange.
Would anyone have a wiring diagram or know why this is happening?
thanks,
Phil
thanks,
Phil
