Mastathrash
EDIT: HAVING CODES READ THIS WEEK HOPEFULLY still fires but won't stay started at all.
97 ls400 fires up barley but will not sustain. JJust replaced PCV valve and many vacuum hoses. Prior to the pcv valve replace the it was running. I tested the valve to make sure it was functioning properly and it was..
Everything seems installed and nice and tight and I fixed all the vacuum leaks that I had... I have tried resetting the battery with the fuse pull and the battery method and neither has worked.
I was having severe misses with the engine, But I decided to fix all the vacuum leaks 1st just in case, I had the tubes and it was cheap and easy to do. I Believe this is an electrical issue and not related to the mechanicals (He HOPES!)
Before replaceing the PCV, the car was not missing and was running reasonably and even getting better gas mileage off the/tak than I have in years! So Which stupid sensor or machine God or goddess did I wind up pissing off?!
ANY HELP OR INPUT IS WELCOME I AM NOT a Lexus Mech.
I am about to try to reset the immobilizer and see if that is the issue.
"Edit: didn't work"^^^^
I ALSO I had a hard start that threw a check engine light PRIOR TO THIS ISSUE so I'm hoping nothing is too f'ed up. I wound up driving at home successfully But the only thing I did came home was replaced the PCV valve and it's hose which looks correct and I definitely didn't get any "nasty's" inside.
I've had this car for over a 100000 spirited miles and I'm not ready to give it up yet. I love this car. But I am not ready to pull and learn to rebuild the engine I just don't have the time and money right now.
I am posting this thread in case other people encounter this issue as I've looked through many forums and there doesn't seem to be definitive answers so for better for worse I will post my journey Solving this problem and hopefully it helps somebody else dealing with the same.
