M millsi New Member Apr 30, 2011 #1 Can the valve springs in the 1uz be changed without taking the heads off? I believe there is a special tool? cheers
Lextreme II Active Member Apr 30, 2011 #2 Yes u can.... no special tool. All u need it a compressor...
P pogoism9 New Member May 13, 2011 #4 Need to make sure your valve doesnt drop into the cylinder. Alot of people use that yellow nylon rope and stuff it down in thecylinder via the spark plug hole to keep the valve up.
ash New Member May 16, 2011 #5 just make up a air fitting, to put 100 psi into the cylinder, while the piston is at tdc the air will hold the valve up
