So I'm trying To Do the pin trick for my 92 SC400 as I have a actron scanner yet regardless of if I use that or the pin trick my CEL won't flash only my O/D light flashes (#2 shift solenoid and VSS, VSS already fixed but code is still there) but the actual CEL won't. Is it that the O/D light pertains to the CEL so that's why it's flashing and not the CEL or am I dumb? I let the car idle until it was at operating temp, set the key to on and left the engine off and hypes te1 and e1 after I did the same thing but with my scanner and it didn't work. Any insight is greatly appreciated.
