CD009 swapped GS400 park/drive
D34D
hello! my first post here definitely wont be the last. just bought someones beat up gs400 track car with a CD009. trying to get it into a condition i can daily.
the way the car works right now is that its always in park. is the car going to run properly like this or are a/f ratios and other things changed when the ecu thinks the car is parked? is there any reason i should be trying to find a way to swap between park and drive?
thanks
It shouldn't impact the AFM, as you're bypassing the transmission ECU, while allowing you to turn on the car, otherwise it would be a pretty paper weight. Hope this helps.
As I understand it (so far) the ECU will nerf the engine power without the trans signals - is it running standalone ECU?
