So a customer sent me this ECU for security off, and I noted the dent on ECU case
No wonder this unit would not start the engine even after security removal. Turned out that it could not detect crank angle sensor signal. So I took a thorough look inside
This SMD resistor easily broken into 3 pieces right when I touched it with soldering iron
Replaced it with closest part I could find (2 resistors of double resistance and half tolerated power connected in parallel)
note how the problem corresponds to the dent on ECU case
So overall if you see dents on ECU , there's possibility of weird things happening inside which are NOT apparently seen when you open the case
![c507506s-960.jpg](https://d-a.d-cd.net/c507506s-960.jpg)
![7107506s-960.jpg](https://d-a.d-cd.net/7107506s-960.jpg)
![a907506s-960.jpg](https://b-a.d-cd.net/a907506s-960.jpg)
![6d07506s-960.jpg](https://f-a.d-cd.net/6d07506s-960.jpg)
