well only ever compared it to one other turbo 1uz that is in a off road stadium truck and i think that had only around 6 or 7 psi, no intercooler, and lacked quite a lot of power compared to my setup. i think its not just how much boost you pump into these motors, but as we all know with all the other extras, like exhaust , computer, intake designs etc thats where the differences come into it.i have a new supercharger pulley on the way, which is the smallest one for the m112, ( 2.75'' ) so looking forward to seeing some major improvementsThats pretty amazing, its like the SC had no loss compared to the turbo.
Good luck !!Thanks for the info, But I am using the stock ECU and let's say 7.5 PSI.
There were no tuner !!!!!
BTW the stock M112 pulley will give 6.5 PSI… right?
i managed 386 rwhp on 7.5-8 psi, with m112
crazy?? computer is a link, also running twin throttle bodys, water to air intercooler, bigger injectors, good exhaust system, etc. not sure how to upload pics but my dyno sheet reads, 386hp at 5744rpm - 115mph. and 524nm at 4165rpm. that was all thru a 5 speed manual, but now car has th350. have run best of 12.3 at 112mphThat is crazy hp gain... What computer?
ahhh i think it was a modified gt4 toyota one from memory. was crap any how. not too much slippage on the road but as soon as the slicks went on, the clutch cried enough more than once over about 3 sets of clutches, so the 5 spd had to go. the auto was around half a second faster over the quarter any way.What clutch system are you running Commy?
For a low boost and economically set up, let's say 7 psi a lower, a FMU and a high pressure high flow 255 Walbro is hard to be beat.I would find some bigger injectors [36Lb +]or run an FMU?? But its far better to let ECU do the tuning!!
A higher flowing fuel pump would be safe ..
A Walbro 255 in tank should do what you want..
Yea initial set up cost wise yes!!For a low boost and economically set up, let's say 7 psi a lower, a FMU and a high pressure high flow 255 Walbro is hard to be beat.
Anyone know what stock 1u fuel pressure is?
