tsirovy
Quick question: When I am removing the journal bolts that hold the camshaft in place, can I remove the journals one at a time without removing the timing belt from the camshaft? I am attempting to remove the bolts one journal at a time to keep the cam in place while the timing belt is still on the camshaft in order to inspect the journals, however the bolts are on soooooo TIGHT that I have cracked 3 different 10mm sockets trying to remove.
Anyother time I would figure you can remove one journal at a time with the timing belt on the shaft still.
