5020Chris
Hi, have stripped the front off the 1uz this morning to do the rotor arms,caps,water pump,idlers, tensioners and cam belt etc and was wondering how the cam belt tensioner works ? Is it a heavy spring of sorts in that tube that is held on with the two studs ? And it has a small hole in the pin that presses on the tensioner arm, do you compress this in a vice and put a small pin in then release it when the new cambelt is on ? It just seems VERY strong to compress and thought i'd ask before I go and screw it up in the vice ! nice one, Chris.
