I have been swapping emails with Kelford Engineering in NZ about their cast cams.
Below is a copy of my communications. Sorry it starts at the bottom and works it's way up. And this post is very long.
I suggest we all hold still and don't inundate Kevin with emails.
I have asked him to let me know when they are ready to supply and I will post it so you can all email your orders to him
it is not a firm price, just a estimate, excludes gst.
----- Original Message -----
To: Team at Kelford
Sent: Wednesday, August 04, 2004 8:56 PM
Subject: Re: 1uz-fe
Kevin,
The price you mention is that inclusive or exclusive of GST?
Thanks
Rod Garnett
To: The Garnett's
Sent: Wednesday, August 04, 2004 8:10 AM
Subject: Re: 1uz-fe
Hi Rod,
No problem, you can post my e mail if you want to.
Kevin
To: Team at Kelford
Sent: Tuesday, August 03, 2004 8:56 PM
Subject: Re: 1uz-fe
Kevin,
Can I use your comments (or post your whole email) on
www.lextreme.com as there are a number of us chasing cams.
We looked at casting cams and having them ground but for the small number we needed it was just too expensive,
Thanks.
Rod Garnett
To:
[email protected]
Sent: Tuesday, August 03, 2004 7:12 AM
Subject: 1uz-fe
Hi Rod
You are correct in saying that you cannot use 'steel' billet cams without lubrication issues.
But as of two months ago I have had one of the worlds biggest cam manufacturers make 'Factory spec' cast billets for us. We use them a lot in NZ for jet boats, circuit and speedway, and up to now we have been either grinding them down to get a decent profile onto them and using longer valves, or hard welding the lobes and re-profiling (this works perfectly when we do it, but is expensive).
So in around eight weeks we will have for sale, finished cast camshafts ground to factory base circle size and any spec that you want. We estimate the cost for a set of finished cams to be around NZ$1500 but won't really know exactly until we have them here.
We have just finished a set for a supercharged application and also a twin turbo drag race application.
If there is any other info that you want please ask.
we also now have off the shelf finished cast billets for 1&2JZ
Regards
Kevin Ban
One last thought.
As we all fit our cams we will need some new shims (there's no way you would be so lucky as to have all 32 fit correctly).
400ZED and I have discussed setting up a shim exchange program where we can post the shims we want and if someone has it (or them) spare they supply it. Shims are around $15,00 each so 32 of them adds up. Any comments on this.
There is also a thread on Toyota Echo shims fitting. Maybe some one can look into this futrher.
