Recently acquired a '92 SC400 engine/trans/harness/sensors/fuel tank etc... This was picked up with the intentions of putting in my rockcrawler... Which currently has a 3zve.
The trans needs a rebuild, which is going to slow down this project enough. The engine also needs some freshening up. Appears it had been leaking oil for a while and has high miles. My plans were to seal it up and worry about maintenance items after the swap is completed.
In the interest of time, I started looking for a lower mileage motor. JDMs are readily available and priced fairly. Does anyone know if the fuel rail and injectors are the same as our market? I've read there is a difference between LS and SC injectors. But would a soarer and a sc400 of the same vintage be any different? I realize that JDM motors should be torn down anyways. That will most likely happen once the conversion is operational.
