RotaSpinna
I've been trying to figure out what the compression ratio of a 2UZFE with 1UZFE heads would be after de-stroking with a 1UZFE crank. Seeing that the 2UZ go past the deck at TDC, the 1.5mm difference in the 1UZ crank stroke should make that irrelevant.
So, I need some help filling in the blanks!![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
2UZ bottom end w/ 1UZ crank and heads...
Compression Ration =
Cylinder vol. + clearance vol. + piston Comp. vol. + gasket vol. + chamber vol. divided by Clearance vol. + piston vol. + gasket vol. + chamber vol.
Thanks,
Andrew
Thanks,
Andrew
