Hi guys,
Been on this forum for a while now but havent yet posted. Im currently in the process of building the first 1UZ powered mk2 supra in the United Kingdom.
Im using an R154 5 Speed from a MK3 Turbo, bellhousing/clutch/flywheel etc from Castlemaine Rod Shop and a 1996 ls400 1uz.
Now this later spec version of the 1UZ uses a Hotwire AFM as im sure you all know and i was planning on using a Crown ECU as i read on this site that it will work with a manual gearbox unlike the LS400 ecu.
Problem i am having is that every crown ECU i have been able to find has been fitted with the earlier LS400 style Karmen Vortex AFM....
So my question is if i get a crown ECU will it be able to just plug in my Hotwire AFM and expect it to work? Or is the signal output from the Hotwire diffrent to the KV?
Thanks guys
Lee
Thanks guys
Lee
