Building 4WD LS400?
Maracon
Hello
Do you quys have eany thots about making the LS400 to 4WD? What is needed?
Aristo/GS 400 oilsump, whit the front diff. Will it bolt to the LS 400 engine?
Hubs and front drivesafts. Can the drivesafts bolt to LS 400 stock hubs correctly makeing the froont drive?
And what gearbox to use? What does the 4WD Aristo use?
Is there eany need to make canges to engine management?
What kind of power does the Aristos front sump take max?
I had a think about this a few years ago.
You'd need a complete AWD front cut to make it even slightly feasible.
You'll have to basically cut the front chassis rails off the LS400 and weld on the AWD chassis rails.
The LS400's rails have the crossmember mounts in the wrong spot, I'd bet that they are not the right distance apart to bolt the AWD subframe/crossmember too, and the LS400 chassis rails are right where the AWD axles need to be.
