timing marks are totally different and belt is wrong length..ahhhhhhhhhhhhh
car is at work blocking up workshop..have to get it sorted asap before hols over or boss go mad!!ie tomorrow!!!
engine is 1uz-fe 1995...dont know what from but UK model..
stripped it down,and what a barsta5d job..everything stuck,getting water pump off took hours!the thermostate housing (ali) bit just would not come out of inlet manifold...
so 7hrs later putting back together discovered noticed before,but thought must be making mistake (original belt had no markings) that the cam timing marks are not at 11 and 1 clock,but at 10 and 2..there ARE factory marks on backing plates behind cam sprockets to align on to...and they line up with cam shaft sprocket marks..(i marked it all up before removing belt)
and then...fitting up belt discovered belt is toooooooooooooo long...its 2 teeth to big..
anyone got correct part numbers/install instructions for 1995 engine (skinny rods)
also tensioner is different lenght.(body that extends downwards)
help!!
help!!
