cebby New Member Jun 18, 2005 #1 Anyone have the bolt torque specs on the UZ auto bellhousing and assorted other trans bolts? Is it OK to use the Toyota red sealer between the bellhousing and the trans or is there something else I should use?
cebby New Member Jun 18, 2005 #3 Thanks Lex - I didn't see the trans stuff on there other than the drive plate. Does that sheet call the bellhousing something else?
Lextreme II Active Member Jun 18, 2005 #4 Ok there are 6 bolts. The 4 upper bolts are 25 ft lbs and two lower bolts are 42 ft/lbs www.lextreme.com/transimission/installation.pdf (page 20-21)
