bellhousing bolt size
The holes for the bellhousing bolts in the back of the block are a 12mm fine thread. I believe they are 1.25 pitch. It is not a common thread pitch for large bolts, so you may have to do a little searching to get what you need.
Steve-O
Anyone know the length of these bolts? I need to pickup some other metric bolts today, so I might as well get these also...
Just an FYI, the length of these bolts was in response to a post about how long they needed to be to put a motor on an engine stand.
They are probably not the correct length to couple the motor to the tranny.
