sourcemine
rpm's drop when A/C is off, when the A/C isn't on the rpms flow from about 700 down to 400 and repeat back and forth.
When it comes down to 400 rpm's the Check Engine light comes on, otherwise it shuts back off. ODB was checked, shop said it was the MAF sensor.
Purchased another MAF to try, any other suggestions?
Also cleaned out the idle control valve which another mechanic said to check becuase it affects the idle speed when it's on/off.
