JustenGT8
Hopefully someone is still up to date on this old clunker of an ECU
I have gone to a VVTi engine from my old non VVTi setup. I have also wired in an 500r CDI box and I'm using Honda CDI CoP. Sideshow redid the loom for me and at this stage I'm assuming he got it right.
Buggered if I can get it to fire though on totally in correct flag mode settings it will fire out of sync so I'm pretty sure all the hardware is working.
With flag mode 13 set at 129 for missing teeth sensor
Flag mode 14 set at 9 to suit the 36-2 VVTi crank trigger wheel
Flag mode 15 sort at 3 to set the sync adjustment ie at 60 deg BTDC the cam trigger is 3 crank teeth (30 deg) off its sensor.
Not a hint of firing with those settings
I think there is a setting elsewhere I have missed but my manual has been no use and I'm out of ideas?
Anyone?
Anyone?
