Hi I would use the factory torque settings as the stud will give a better pull down and will be close to the required torque . the only problem with this is that the head torque specified in 2 parts it requires you to tighten down to a specified torque of i thinks its a about 35 ft/lbs you should checks a manual first on that one and then you tighten the bolts or in your case studs thru 2 lots of angle turns 90 deg and a further 90deg . the real problem with that is that the factory bolts are meant to stretch when you do this, so i guess my first bit of advice would over tighten the head . ARP should be able to help you . or an experianced engine builder will give the right advice .
Gee talk about going the long way to answer a question
Please disregard my first statement as i think it is incorect.
Another factor to concider is the type of head gasket weather it is a multi layer metal shim type or the std factory type as this will affect the finisded torque settings.
Now i am sure i have not answered question but i have had a ramble .
Regards oz.
