Are O rings necessary with Copper HG
Actually right now, the company i deal with made a new copper gasket with build in O-ring. Pretty insteresting. The O-Ring is sandwhiched between the copper.
With a properly prepped block and head surface and a good multilayer gasket there is no need for o-rings. Look at the Cometic MLS headgaskets.
O-ring seal the combustion chamber really well but sometimes you get coolant seeping down the side of the cylinder head.
you could also sleeve the water and oil galleries in the block with matching recesses in the head.
that will eliminate all bypassing.
