While trying to find some performance parts for the 1UZ enigne, I came across the Jet Performance web site. They don't list any 1UZ aplications, but they can do customs and have done Supras. All I really want is the rev limit and shift points raised a few hundred rpm. I figure 6500 should be no sweat on these motors. If it is anything like the 2AZFE in my 04 Camry, (it pulls hard right until the rev limiter cuts the fun at just 6200 rpm) then a few more rpm will be very welcome. On their web page, Jet lists increased rev limit and shift points as some of their primary "fixes". They also adjust mixture and ignition timing to optimise the engine. The 1UZ is coming from a 93 LS-400 and is going into my 83 Celica GT-S, complete with the stock ECU and auto trans due to the California smog laws which require all stock emissions controls to be in place AND WORKING. My Celica is about 1000 pounds lighter than the LS AND it has a 3.727 rear end (LS has a 3.62) and I race on 22.5 inch tall tires (LS tires are about 26 inches). This will make it run out of rpm very quickly. I am also planning on some mild cams and maybe some porting to help it breath up at 6500. My previous engine was a very built 2.4L 22RE with a turbo setup and I revved that to 7200 rpm regularely. Trying to shift it before 6200 was near impossible as it ripped to 60 mph in under 5 seconds. Of course the W58 second gear is a bit shorter than the A341E second gear but it should still be a short trip to redline.
I plan to send Jet an e-mail to ask if they can do a 1UZ ECU with just the raised RPM numbers as Toyota did a very good job in the first place, I doubt there is much to be had with just a chip. With other mods, the stock ECU may start to show more merit, but the learning ability of the ECU can "un tune" any changes to the fuel map and ingition timing. I will run the motor stock for a while, but some mild cams and porting is probably in my future as well. My turbo beast was close to 300 crank HP (Probably 250 at the wheels) and I want to come close to that with the 1UZ.
Gary M.
Gary M.
