![Mad :mad: :mad:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f621.png)
I had a big problem of not running good and no power. I put in a new fuel pump,coded check engine light to maf (swapped one from a junk yard). Did some diagnostics and it said that the ECU needed to be replaced. I sent the ECU out for repair and it came back. PROBLEM STILL NOT FIXED.
I send it to Lexus and they say the coil is bad and they replace it. My son drives the car home. When we get home , I drive it down the street.
I notice it is going from 1st gear right to 3rd gear. When you floor the gas it does not down shift to 2nd gear. If you put the gear shifter physically into 2nd gear, it down shifs to second and everything seems to work but you have to do it manually.
A half an hour later.
The car will start and idle but when you give it gas, it boggs and wants to stall. If you leave your foot on the gas it will bog bog bog and rev to about 1500 rpm.s and repeat . I can't even take it out of the driveway.
What happened in that 6 or 7 mile drive home from the Lexus dealership ???
