this is George Contranidis's RA28.
he runs what used to be GURU motorsport in Bunbury, West Australia. i think it's called "adrenalin" now or something...
in those pics...that 1UZFE is 100% internally standard (including cams!) and took a total of 35 9sec quarter mile passes on 22psi before it went pop.
apparently it was running great until they tried 25psi on their 36th run.
runs a MoTeC injection system, CDi ignition, eight Indy Blue injectors flowing methanol and individual coilpacks for each plug.
twin GT30R turbos, twin 45mm PROGATE wastegates with 50mm exhaust manifolds and 4in dump pipes. only the top half of the inlet manifold is custom with a 115mm throttle body. i heard he has upgrade to bigger turbos now though.
powerglide auto with an undisclosed stall.
9inch diff with 3.5:1 full spool strange gears and a ladder bar rear end.
no cutting was required to fit this engine and it's turbos either in that guise. bastard...
![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
