I gotta give it up to Toyota. Recently I was blessed with a gift. My neighbor gave a cherry 1995 Toyota Previa (Tarago for down under) with a Supercharger. I subscribed to TIS and read most of the mechanical and engine articles.
This Van has a Mid engine configuration. Wow what a great way to optimize the weight distrubution.
It has lower compression for supercharged application along with oil nozzles for the pistons. This 2.4L engine has cast iron block with aluminum head. The supercharger is also intercooled amazing....
Another thing... the supercharger is linked with the serpentine belt. So incase the supercharger belt breaks, the rest of the accessories will still be running. I also noticed the exhuast header is very well designed with high flow compacity. Oh... did I tell this 2TZ-FZE (engine code for supercharged version and 2TZFE is non supercharged) is powered by timing chain? Timing chain will out last more of the mechanical parts. Secondly, the supercharger only comes on when its in mid to high rpm.
The Previa I got has blown head gasket and will be replaced with a low milage Japanese imported motor. This little motor was designed for boost.
