alternative power steer options
BigEv
Hey guys, ive been on and off here for a while now and starting to get into more modding.
im after some info/help regarding power steer options.
are there any companys that do mounting brackets for aftermarket power steer pumps?
im wanting to mount a GM power steer pump on my 1uzfe.
any insight would be appreciated.
Evan
None that I've ever heard of.
You will need to fab up your own brackets.
Alternatvely use an MR2 electric power steering pump.
yea im looking at the electric pump but im wanting to run hydraulic steering with it. so will need high flow a a fairly high pressure
evan
Have you posted on outerlimits4x4.com on this?
All I could suggest is fab up brackets for whatever pump you want to run.
I'd be surprised if the stock pump didn't flow enough or couldn't be modified to flow enough for your needs.
