Alternative oxygen sensors
Zuffen
Super Moderator
Staff member
One of my Oxy sensors fouls on a chassis rail.
I can plug the hole and fit it elsewhere but figure there must be alternatives out there.
From my reading all single wire units work on the same principle/voltage. On this basis has anyone fitted an alternative O2 sensor that is shorter. I need ones that are 25-40mm (1-1 3/4") shorter that will bolt into the standard holes. Termination of wiring doesn't matter.
I looked at bending the probe but as it has a ceramic core it (obviously) cannot be bent.
All suggestions appreciated.
