I have an extra Mass Air Flow unit and this is the most restrictive part of the intake system and is very sensitive to change...I tried removing the very front mesh screen to increase flow and the engine ran like crap..Quickly put it back on...Now looking down the inside there is a pertuding plug bolt end that looks like it may restrict some air flow...It is a plug bolt...I am thinking of grinding it down flush...Better yet if possible grind out the inside divider...Now do you guys think that will effect anything? Here are some pic's of what I am trying to explain....
This end bolt that I would like to ground flush is almost visible in picture #1 at the right side of the inside of the MAF near the wire screen.
Maybe I should have posted this in the engine section...ooooops. too late now..
