almost done..blew gearbox up again so while waiting for rebuild doing sc install..
so..
A.)vac pipe take off to brake servo...comes from intake to supercharger after throttle body???..yes or no (if no,where from please??)..
B.)vac pipe to supercharger boost bypass valve..from same as above??yes or no (if no where from please??)
C.)engine breather pipes..one way valve from one bank going to inlet manifold after s.c....valve blocks boost from entering bank..other bank vents to inlet to sc,no one way valve..vents before or after tb??is this correct???what one way valve to use??
thank you..
so..
thank you..
