My project for the 1UZ includes a dedicated LPG based SFI system and mild boost from a supercharger. I thought I had a cunning plan for intercooling the charge air by putting a fintube cooler in the intake manifold, and flashing the LPG on the tube side from 10-15 bar down to 3-4 bar. I felt that the JT effect of the pressure drop, coupled with the state change in the LPG from liquid to vapor would have a dramatic cooling effect. Enough, I hoped, to chill the charge air down, as well as vaporise the propane, Win-Win for both sides as it were. I consulted a Spanish colleague of mine who has probably forgotten more about heat transfer and enthalpy than I'll ever know, and he was happy to run a process simulation for me (I think he'd secretly like to be building high performance motors, too). He used a process simulator software called HYSIS, which is highly regarded in the gas processing industry. He also did a reality check of the HYSIS results by running the same equations of state manually.
For those of you who aren't into thermodynamics and heat transfer, the bottom line is that my cunning plan won't work. There's simply not enough mass flow of LPG in comparison to the air flow, to accomplish significant intercooling. So, I present this only as free data for anyone who might consider trying this, or something similar, in the future.
Here are the parameters I gave him to work with (sorry for all the -----'s I can't figure out how to space the characters to keep the table formatted)
------------------------Pressure-------------Temperature
-------Flow-----------In-------Out----------In--------Out
LPG: 1.2kg/min-------15bar----4bar---------25C-------????
Air: 25 kg/min---------2bar----2bar--------140C-------????
Here is his analysis:
OBJECTIVE OF THIS CALCULATION:
FIND MINIMUM AIR OUTLET TEMPERATURE THAT CAN BE ACHIEVED
Imagine you manage to expand the LPG liquid through a valve just to the bubble point, this is to say, that starting to boil liquid can enter the exchanger. This is the best case you can have, as vaporization heat can be completely given to the other fluid (air). Normally this is desired as vaporization heat is in the order of 1000 times the equivalent non-state change heat flux
Of course, a real isenthalpic expansion through a valve will cause LPG partially to vaporize (or all LPG, because of the high amount of a single component, starting and ending boiling points are very close, near 4ºC difference).
Let’s assume we have the first case and no vaporization is found at the entrance of the exchanger. In order to be in a more optimistic case I assumed bubble point at pressure 2.75 bara (temperature -8ºC).
The pinch analysis is an easy tool to determine thermodynamic constraints within an installation. It is a comparison between the available energy of both sides of the exchanger and which is the maximum temperature (for cold fluid) and minimum (for the hot one) that can be achieved in an exchanger of infinite area an infinite residence time (this is to say, the thermodynamic limit)
As you may find in the attached "Pinch" graph, the limit is 109 ºC. This means that, the outlet air temperature will be always over 109 ºC (this is in accordance with the hysis result of last days, outlet air temperature was around 130 ºC).
As heat capacities are in the same order for both air and LPG, significant difference in the slopes of the curves you can see in the graph, are due only to the ratio of mass rate (25:1). We will conclude that the mass rate of LPG is not enough to cool down the air.
Fuel composition, is 90% propane, 5% propylene, 5% butane. All physical properties are close enough to propane so as to use them for the study. Please find below, Pressure- Temperature curve for the automotive fuel (maybe you find it useful for further calculations)
