Was lowering my car today after checking the exhaust and suddenly there was a rush of air coming from around the compressor area.
The car quickly sank to it's bump stops and would not re-pressurize, despite the compressor working full pelt.
So I whipped off the wheel arch cover (sound of escaping air came from there) and found the problem.
The air is being blasted out of these two small holes in the plastic cylinder.
What worries me is that it looks like it is supposed to do that, which means it's not just a simple leak.
Does anyone know what this part is, and why the system has stopped holding air?
The compressor will run if I plug in my aftermarket ride height controller.
If I disconnect the ride high controller, the hi/low light will flash on the dashboard and the compressor will not run.
If I connect the ride height controller, the light will stay on and the compressor will run, but the system wont pressurize as it is jettisoning the air out of the cylinder.
Any help would be appreciated![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
![30072010741.jpg](http://img265.imageshack.us/img265/9834/30072010741.jpg)
