Hi Guys,
I pretty much run a quality 10W mineral oil in my 1UZ-FE V8 nowadays with excessive changes at 5000km or 3000 miles. For special events I'll run a 0W full synthetic motor oil (events like a dyno day or a weekend of 220 kph circuit sprinting)
Without a doubt quality oil will "last" longer than 5000 km without breaking down.
Topping up the oil will also make it "last" much longer as well. I never lose enough in 5000 km to warrant topping up at all.
I guess I change the oil so often because it makes me feel good! Like washing the car I like to keep the engine clean and slowly make it cleaner. Even though the oil doesn't break down, it does get contaminated with fuel and other combustion by products and the filter does block up.
I like to run the standard PCV (replaced the valve with a new one ) system so that the inside of the engine gets nice fresh filtered air and acidic conaminants are removed. I haven't had a problem with detonation.
I have travelled approx 90 000 km (56 000 miles) with this engine and the wear metals in the oil are satisfactory each oil change.
I am unable to judge oils by inspection during a service or by colour on the dipstick! Superpowers like that would save me lab analysis money!![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
So it would seem after several analyses that for a short 5000 km interval there is no difference in engine protection between a full synthetic oil and a mineral oil.
There is plenty of evidence that a full synthetic oil has better lube properties and is the only way to go for an extended service period. But for a 5000 km change the lab couldn't measure any superior properties.
The lab analysis is also handy for finding out what is in oil and how different companies approach their formulaes. Check out the levels of moly added to oils for example -some are low and some are high (link at bottom of page).
It would also appear that a TRD oiled cotton air filter is satisfactory for filtering air. The engine oil is exposed to dirt in the intake air through the pcv system and as a part of the combustion process. An oil analysis will clearly show if there are leaks in the air intake system and the levels of dirt contamination in the engine oil and and correspoding increase in wear metals.
There is some more information on this page including the oil analysis results.
http://www.planetsoarer.com/OilAnalysis/OilAnalysis.htm
best regards
Peter Scott
best regards
Peter Scott
![Clip_2.gif](http://www.planetsoarer.com/OilAnalysis/Clip_2.gif)
