air con and egr removal?
shifty biscuits
hi. i need to find out how to go about removing the air con pump from my engine and what you do about the aux belt when its gone? it looks like it will need to be a lot shorter and maybe be routed differently? can anyone shed some light?
also the egr pipe on the rear of the engine is broken, if i blank the holes at either end will it be ok or do i need to remove the whole lot? if the latter how do i go about it and which parts can be taken off?
thanks.
