Hi,
I am planning on using an aftermarket ECU with my 1UZFE (LS400) Powerplant. At the same time will be doing a conversion to Manual to get wrid of the automatic gearbox, hence the reason for not using the OEM ECU. Locally in my country there are a number of ECUs available. Ranging from Gothech, Spitronics, Dicktator.
Is there anyone on this forum that has used one of there before with a 1UZFE? or do you know of a better ECU that I should be looking at?
Base-maps, Wiring Diagrams etc will also be usefull to look at in making a final choice on ECU.
Thanks.
Thanks.
