Been searching multiple websites including this one and no luck with my issue.
92 Lexus SC400 1UZ to a 86 Toyota 4Runner
Almost finish this swap and now having some issues. Motor starts up and revs good. It’s getting everything it needs but it has 5 DTC.
7: TPS
29: Right 02 sensor
31: AFM
32: AFM
41: TPS
Tested all wires to the ECU and everything is connected and my multi-meter beeps every time. Switch out a new AFM and still same codes. Disconnect the sub TPS for TRAC control and still same codes. I did not modify any wiring related to TPS and AFM. O2 sensor I did touch and less concern about that DTC. The code 7 is not to be found on my FSM, Im not sure why Im getting that DTC. I’ve search further and found it on a few sites as an issue linked with TPS. Am I overlooking something here?
I was told or read the 92 1UZ with TRAC control can cause a few problems. But I have also read it was more of just wiring issues. So, I am not sure what to do. Should I get a new ECU? I don’t really want to spend more cash if I don’t have to. I bought a complete running Lexus SC400 and it drove well with NO check engine lite. Please help direct.
7: TPS
29: Right 02 sensor
31: AFM
32: AFM
41: TPS
