Adapting a341e to tacoma t-case
Munchies
I want to adapt the v8 auto trans to the tacoma t-case and use a marlin crawler doubler kit. What parts do I need, new tailshaft housing/tailshaft?
let me rephrase what I want/need.
1uzfe/auto trans/ non 2wd output housing..
I need to bolt up a passenger side drop transfer case behind an auto, behind a 1uzfe.
How can this be done?
get a taco auto 4wd trans/transfer swap output shaft from taco auto to 1uz auto tap out 2 holes to take extra mounting bolts and bolt up the taco transfer, its as easy as that, depending on the model the output shaft may not need swapping out just shortining as per the taco auto, the auto is the same family an is very simular, there is a thread on this with a forerunner/surf so do a search
