225/60/R16 sized wheel travels 2.125 meters per single revolution. Or you can say it makes 0.47 of its complete turn per every meter. With diff. ratio of 3.27 tailshaft makes 1.54 turns per meter. Each turn produces 4 pulses of the reluctor type speed sensor (one that connects to SP2+/SP2- terminals of the ECU, but there's one more sensor in the tail piece of transmission). So we have 1.54*4=6.15 pulses per meter, or ~10.000 pulses per mile
So...as long as you know pulses per rev, you can translate them into pulses per mile as I shown you. To check 2-wire sensor's pulses per rev, you unscrew the sensor, rotate tailshaft and count the teeths you see through the hole. To check 3-wire sensor's pulses per rev, you will need a couple wires and small bulb (best if you find LED bulb)
