P Bateman
I need to return some videotapes.
Through the process of building turbo 1UZ E36 BMW, I'm changing the valve body so it can handle boost more effectively.
PROBLEM - the Soarer 1UZ A340E valve body uses:
SOLUTION - installing a Prado A343F valve body provides:
The valve body bolts in without any issue and the wiring harness is an easy swap. The only issue is that the A343F has no drain hole under the Clutch-0, so the Soarer accumulator has been replaced with the Prado unit - it fits without any issue, but makes it hard to install the valve body in the car.
Further to this, I used the casing plug from the Prado to plug the hole left once the throttle cable was removed. I've also fitted the Prado oil pan as it takes another 5 litres of oil.
The only drawback is the Soarer has a linear solenoid for the torque converter lockup (SLU) and an internal oil temp sensor
The Prado uses an on/off solenoid to run the torque converter lockup and the temp sensor is fitted externally in the cooler outlet pipe.
Once I have the car running/tuned and have some time to play around with the Haltech auto configuration, I will post some results.
- cable from the throttle body to control line pressure (the more right foot you give it, the more pressure you get)
- solenoid to control accumulator back pressure (modulates the clutch/brake application to make it smooth or firm)
- solenoid to control line pressure (mapped to boost instead of throttle position)
- accumulator pressure is internally linked to line pressure (two birds with one stone)
